Uatx power supply
Feb 26, 2018
16
Hi I have a uatx power supply I have and I need to upgrade to at least a 500w supply. And reccomandations?
I am looking for more reputable brands like evga and not small brands I've never heard of pleased.
Every UL certified psu will have a data plate.
It should have the name and the wattage.
In particular, you want to know the watts or amps on the +12v rails.
GTX1050ti does not usually need a 6 pin power connector, so such a card will likely be a safe upgrade without a psu upgrade.
Measure the dimensions at the rear of the psu. A standard ATX psu will be 150mm x 85mm.
If you see that, you are likely ok to replace it.
Look for a tier 1/2 unit from a list such as this:
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
Seasonic is always good.
I particularly like the Seasonic focus units, here is a 450w version:
On sale for $55 after rebate:
https://www.newegg.com/Product/Product.aspx?Item=N82E16817151204
What is the make and model of that PSU? Which PC is it inside of? Does it have a make and model number.
Usually I'm pretty good with computers. The problem is I was going to buy a 500w bronze psu but I checked the specs on mine and it said uatx and I've never heard of such a thing. I wanted to make sure it isn't some small category of power supplies I somehow haven't heard of. I wanted to upgrade possibly to a 1050 ti or a 1060 when prices calm down btw
What is the PC's make and model number? PSU? The Corsair cx550W is a relatively inexpensive but quality PSU solution. I'd skip the EVGA 500W 80+ Bronze if that was one of your options. If you can handle it the Seasonic G Series 650W 80+ Gold PSU is usually about $69 and is semi modular. The 550W PSU will be fine for anything up to the GTX 1080.
It looks to be a regular ATX PSU. Is there any way you could measure the length, width and depth of the PSU? You are right that that PSU can easily function with a 500W PSU. Just make sure it's a quality unit. I had that EVGA 500W PSU with a EVGA 970 FTW and a 4690K, 5 drives, 8GB RAM and the rest.I just don't want to assume and steer you wrong.
