Good Afternoon all.
I'm looking for some information regarding my SATA HD and whether or not the actual SATA (II?) Cable supplies power to the HD.
A little back-story: About a week ago my computer would randomly shut off after some time of use (anywhere from 5 minutes to an hour). At first I assumed it was a power supply issue, so I did some trouble-shooting changing the outlets, power cord and even the power supply from an older PC that had been sitting in my basement. The problem ensued, so I figured it might be a power issue with the motherboard.
I reinstalled the original power supply. I switched the SATA cables between my CDROM and HD to see if it could possibly be the cables. When I booted up the computer I noticed my HD was silent and I got the "Insert Boot DisK" or w/e prompt when you are first installing an OS on a new PC... so my HD now is not powering up/working.
I did some research online and the consensus seems to be that the SATA cable does not act as the power cable for the HD, and there is supposed to be a second cable for power? The oringal power supply I reinstalled does not have the proper power connecter to connect to my HD... and I can't remember if it had a power cord connected to from the beginning. I tried a bunch of combinations between the SATA cables and slots on the MoBo.
After 4 hours of messing with the thing, I'm pulling my hair out. Anyone have any ideas what my issue could be? I'm afraid I may have fried my HD in some way from either static shock or from connecting the power cord from the second power suppy when I was testing it out to the HD (along with the SATA cable connected at the same time) - although it did run fine with both cables connected, other than the original issue of it powering down after some time of being on.
Also, back to the ordinal issue, I believe it was a MoBO power issue (although I didn't see any swollen or blown capacitors) because when it powers down the actual power light on the computer stays on, just the motherboard itself seems to de-power.
Any input would be greatly appreciated.
