[SOLVED] (UK) Fractal design R6 - Top Panel
May 28, 2020
5
I'm wanting to replace the standard top panel with a ventilated option. I've asked Fractal design if they do one but haven't had a reply yet.
If necessary I'm happy to cut out a section of the panel and create my own.
Anyone know where I can get black metal mesh should I have to go down this route?
Also I'm finding it very difficult to seperate the filter from the top panel.
There's a video on the Fractal Design website that makes it look like it seperates easily, but mine is very tight and I'm worried that it'll break if I use too much force, or distort the metal panel. Anyone know if there's a trick to getting them apart?
