ultrawide monitor advice (massdrop vast)
Pc Conquistador
17
Before the release of the massdrop vast I was pretty set on the Samsung chg70. However after the release of that I am now deciding between that and the more expensive chg70. What would you recommend for casual gaming on a r9 390 with an emphasis on immersion and beauty of the screen. I do intend to upgrade my graphics card soon to better suit higher resolutions
The 3440x1440 resolution of the 35" at massdrop is beyond what your current card can do at what I would consider decent graphics settings. I am also not a fan of the chg70 because it has blurry text. My concern with the ultra-wides is that I find them too short. Meaning their vertical height is not good enough. I suggest you go look at one of the 34-35" monitors in the store. There is no practical difference between 34/35 as an inch diagonal on such a big scale translates in to a very small % in height.
Also I know many have been happy with generics when it comes to screens, but I am fussy about image and text quality. Ultimately in order to get the text quality I wanted, I went with a Philips 32" It is only 60hz. I may upgrade...
Also I know many have been happy with generics when it comes to screens, but I am fussy about image and text quality. Ultimately in order to get the text quality I wanted, I went with a Philips 32" It is only 60hz. I may upgrade to the LG 32GK850G once it is released. This is the size and pixel density I prefer. I started with the assumption that I wanted an ultrawide.
