Unable to get Display in TV using VGA Cable
KIRAN TJ
48
XPS 435 MT
Windows Vista Home Premium 64-Bit
512MB ATI RADEON 4850 GRAPHICS
8192MB (4X1024,2X2048) 1067MHZ
Intel i7 Processor - 2.66 ghz 8 mb
HARD DRIVE : 1TB SERIAL ATA (7200RPM)
Steps Performed:
Customer was using DVI to VGA convertor and connecting the TV using VGA Cable, where he is getting Error “0033” on the bottom right corner.
Tried another port and Monitor Self test passed
Using 40” Monitor there is No Video on the screen.
Pl advise
bostonmike
62
Default resolution on the card may not be correct for the display. If they have another monitor, hook it up and power it on. See if the desktop is visible. Then hook up the 40 in monitor as a secondary display. In control panel, set the correct resolution then switch the primary and secondary displays so that the 40in one is primary.
KIRAN TJ
48
Card supports a resolution of max 256 * 1600 - (Dual Link DVI) & VGA 2048 * 1536
Unfortunately no secondary monitor available at the moment , would try to arrange one later
Similar threads
