G
Guest
Guest
Archived from groups: comp.sys.hp.hardware (More info?)
Hi all,
I have an HP 9895 pavilion. The fan died and then subsequently the PC
shutdown. I replaced the fan (this is the fan in the fan tunnel)with
a fan that I bought from FRYs with similar rating and dimensions. Now
when I switch the power on, I can hear the drives start up, see the
fans running but there is no display. The display has the yellow light
on (indicating there is no signal, it is green when there is a
signal). I don't even get the blue HEWLETT PACKARD display before it
looks for the operating system. I have checked the display on another
system and it works fine. I have also tried a different display on
this PC and still it doesn't power up. I understand this could be some
kind of thermal shutdown, and if so how can I fix it.
Secondly if it turns out the mother board is fried, I would like to
use this hard drive to recover my files. What can I do? I understand
that I could use this as a slave drive in another machine. When I
look at the hard drive it says jumper j50 is configured for a master
drive and slave drive is off. How do I make this a slave drive on
another system (HP Pavilion 8637).
Any help you can provide will be greatly appreciated.
Thanks,
KKumar.
Hi all,
Thanks,
KKumar.
