Hello everyone!
I recently built a mini-itx PC using the Coolermaster Masterbox nr200p MAX which already comes with a 280 mm watercooler and two 140 Sicleflow fans, so far quiet, but when I put it to work, it makes an unbearable noise even at "idle" , the strange thing is that only in its normal position does it make this noise, if I lay it down, turn it upside down or tilt it more than 45* to either side, the noise stops...
Can you shed some light on how to solve this problem?
I recorded some videos for you to see:
Noise at 100% CPU:
https://youtube.com/shorts/TkSh7t1aE5Y?feature=share
Idle Noise 2:
https://youtube.com/shorts/YlXQCMEwTTY?feature=share
Idle Noise 1:
https://youtube.com/shorts/cHJu0NcwbUo?feature=share
Photo of how it is installed (It is installed on top of the cabinet):
Noise at 100% CPU:
Idle Noise 2:
Idle Noise 1:
