Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
"Paul" <nospam@needed.com> wrote in message
news:nospam-2011042109290001@192.168.1.177...
> In article <419fe233@dnews.tpgi.com.au>, "sheer" <sheer@sheere.com> wrote:
> > "George Molnar" <b4b3@coder.hu> wrote in message
> > news:ODOnd.28046$ha.13026@news.chello.at...
> > > hi!
> > > I've got a little problem with the underground 2. It's freeze for 4-5
> > > seconds when I came out from a shop or I start a race. I try to change
the
> > > videocard, the memory, the windows, but it doesn't work. I've got an
ASUS
> > > P4C800-E Deluxe motherboard, and I think, this is the bad hardware.
> > Are you sure there is not a patch for the game to fix this? Does your
> > computer do this any other time?
> I had a computer once with a problem like this, and it turned out that
> AGP DMA/Dime wasn't enabled. Games were smoother after installing a
> different version of chipset drivers and video card drivers. The
> options menu item of the Powerstrip program, can tell you something
> about the correctness of the drivers installed. As can DXDIAG from
> the DirectX install.
http://entechtaiwan.net/util/ps.shtm
> Another possibility, is that the program is running low on system
> memory. Do you observe swapping to disk, during the 5 second delay ?
> Paul
Diagnostic report - generated on 11/21/2004
PowerStrip build - 450
Windows build - v.5.1.2600.2.Service Pack 1
DirectX build - v.5.3.0000001.0904 built by: private/Lab06_dev(DXBLD00)
OpenGL renderer - (n/a)
System board
Type - Intel
AGP aperture - 64 MB
AGP transfer mechanism - DMA
AGP non-local memory - 124.9 MB
AGP revision - 3.00
AGP transfer rates supported - 4x, 8x
Current AGP transfer rate - 8x
Sideband addressing - Enabled
Fast write protocol - Enabled
AGP texturing - Enabled
Graphics card #1
Identity - ATI Display controller
Memory clock - 337.50 MHz
Engine clock - 378.00 MHz
IRQ - 16, shared
AGP revision - 3.00
Display driver - ati2dvag.dll, v.6.14.10.6476
DirectX driver - ati2dvag.dll, v.6.14.10.6476
Attached monitor - LG FLATRON F700P (LG)
Monitor caps (1) - 1920x1440, 98kHz, 160Hz
Device enumeration
Ensoniq Audio device (58801274h) - using IRQ20
3Com Ethernet controller (001310B7h) - using IRQ21
ATI Display controller (4E481002h) - using IRQ16
ATI Display controller (auxiliary) (4E681002h)
AsusTek CPU-to-PCI/AGP bridge (25788086h)
Intel PCI-to-PCI/AGP bridge (25798086h)
AsusTek Universal serial bus (USB) (24D28086h) - using IRQ16
AsusTek Universal serial bus (USB) (24D48086h) - using IRQ19
AsusTek Universal serial bus (USB) (24D78086h) - using IRQ18
AsusTek Universal serial bus (USB) (24DE8086h) - using IRQ16
AsusTek Universal serial bus (USB) (24DD8086h) - using IRQ23
Intel PCI-to-PCI/AGP bridge (244E8086h)
Intel PCI-to-ISA bridge (24D08086h)
AsusTek IDE controller (24DB8086h)
AsusTek IDE controller (24D18086h) - using IRQ18
AsusTek SMBus (24D38086h) - using IRQ10
I can't see the problem. And you? Where is the AGP DMA/Dime, what you said?
George
