I just built my new system and everything is running well. The last piece I'm trying to setup are my fan curves. Below are the fans that I have.
SYS 1: 140 mm rated at 42.6 CFM @ 1200 RPM, 3 pin DC ,top exhaust
SYS 2: 120 mm fan rated at max 65.51 CFM @ 2000 RPM, 4 pin PWM, rear exhaust
"Pump" fan : 2 x 140 mm rated at 41 CFM 1000 RPM, 3 pin DC power, front intakes
CPU Fan: 120 mm rated at 66.17 CFM @ 1550RPM PWM intaking from front of case to the rear.
What I don't understand are that I have the 2power connectors for the two front intake fans connected together so that only one 3 pin plug goes to the "Pump" fan, I can only use this space because it's the only one that can be reached. Since this is DC and 12V when I adjust the voltage does it get split between the two fans that power is being supplied to so that at most each fan gets 6 V or does each fan get 12V?
I have a general idea of calculating the intaking and exhaust CFM but what about the CFM of the cooler? I know it capacity but how much of it can I judge to be intaking or exhausting??
My plan was to then set a speed of about 20-30% of RPM from 0-50 degrees so that the intake slightly exceeds the exhaust and then ramp up accordingly as temperatures go up every 10 degrees to about 80 when all fan are running 100%.
The GPU has fans but I think I will let it run itself.
