[SOLVED] Undervolting with CTR 2.0 does not seem right
Herr B
180
36
4,690
hello there,
I have an ryzen 5950x and wanted to try out ctr 2.0.
Pretty much all I did is pressing the Diagnostic button. Its on the undervolting test now. Diagnostics running over an hour already. Its at set 58 0.845V. Temperature / wattage does not change.
Test is running for over an hour. feels like the voltage is not applied correctly.
This seems odd to me. might be because I set CPU TEL (V) to 1.25 in bios already?
Hey there,
Ideally if you are going to use a program to undervolt, your system should be set at default. So, reset your bios to default. Then use the program and try again.
You can use HWMon/Info to monitor the undervolt and confirm if it's applied or not.
