I'm currently testing my overclocks and trying to find my best numbers but I noticed that when my computer is under a full load when using prime 95, I start to thermal throttle
I get
core0@ 68 C it never goes above
core1@ 95 C never goes above that
core2@ 105C which is causing the throttling but I am stable, and am having no issues, again this is at full load
core3@87C and never above that
Package @ 105C right with core 2
at idle my cores never get above 57C, and under normal load all of them are within 5 C of each other in the 80-90C range
It's an old I7-3770k on z97 OC formula
I am well aware that I am extremely pushing this equipment, and I have seen uneven temps in this same pattern (core 0,1,2,3 wise) on my old rig, but not to this extreme is this just something with the hardware design of the chips?
Ive reseated my coolers multiple times even used a micro gram torque wrench to make sure my screw pressure is all equal so my cooler is definitely flat and level and I know i seated my thermal material right.
I'm not super concerned because I never reach these temps under normal load but, I can't help but wonder if I'm missing something, or just being paranoid.
Thanks in advance
I get
Thanks in advance
