G
Guest
Guest
I have just performed a Memory Speed Test on my machine and the read speed is 562MB/s which is comparable to other similar machines... However, the write speed is 42 MB/s and the copy speed is only 36MB/s... A fraction of comparable systems, ie same CPU with PC100 memory, the readings should be around 500-600MB/s and 300MB/s respectively.
Is there something wrong? Or have I been ripped off when purchasing the supposedly PC100 SDRAM? How can I improve it if I am running win2k professional? (BTW I have done the test in win98 and yield the same result)...
Here'e the spec. of my machine:
AMD K2-6 300 Mhz
192MB 'supposedly' PC100 memory
15GB harddisk
Chipset: VIA 82C597 rev 4
(This do support PC100 memory)
Any advice will be very much appreciated.
Hoi
AMD K2-6 300 Mhz
15GB harddisk
Hoi
