[SOLVED] Unfortunate Victim of Reset stuck at 41% What to do
kshimoav2
4
So i got an ASUS Vivobook S15 X510UF
And i had to do a bit if cleaning so i did use the Full Reset function that Windows 10 has to offer
I am currently at my 41% of reset and it has'nt move since then
this is my 4 hours already
Any useful note or info on what to do if this happen to fail after waiting for another 3 hours?
If the temperature for any given component is within the specified operating range then that would be, to me, "normal".
Look at the overall system behavior and temperature changes. I would be more concerned about re-occurring and rapid temperature changes. Up and down, up and down, etc. versus increasing to some steady state value.
As for speccy:
Google "are speccy temperatures accurate" or similar words and phrasing. Limit the search to the last year or so.
Based on what I found and read it appears that any given answer could lead to interesting discussions....
What do you mean by a "bit of cleaning"? Did you physically open the Vivobook or were you just deleting files?
Did you use any third party, non-Windows, software?
What led to using a full Reset?
Will the Vivobook boot into Safe Mode?
No i just used the full reset function because i cant format it.
i dont have a windows installation media that time.
I already solved the problem
i just have to wait for another 4 hours tho
a total of 8 hours resetting a laptop
what a joke.
specs is
i3 8th
4GB
1tb
Mx130 2GB
got my laappy formatted from 10 Home to 10 Pro 1909 and im rocking it already.
Can i ask you a different question?
what can you consider a normal temp under load on that specs?
I am currently sitting at 60
and 55 for MX130
(after playing esports)
i dont even know if speccy is accurate
As for speccy:
