I have a Dell Optiplex 745 Small Form Factor, it is not my main PC, however since FIFA 14 is cheaper on the PC than PS3 and not graphically intensive I thought I'd do a little upgrading to it. My worry however is cooling. The reason I say my problem is unique is because I've not found any case/fan mods for this case with the modifications I've done to it. Originally I had an old xbox fan modded to work off of USB power stuck to the back.
(Click Here For Full Size)
This was fine - I have also reversed the CPU fan so the xbox fan was acting as a intake fan -however I've got an Intel Core 2 Quad Q6600 and a Sapphire HD 7750 LP on their way to give it a bit of a boost. Due to having a PCI-E card I can no longer keep this configuration as it's blocking the connections. The "modifications" I spoke of earlier is simply the fact I've removed the large Hard Drive that came with it and put in a laptop Hard Drive I had laying around, It is stored away under the DVD drive where the floppy drive once was. This helped cool everything down a bit as there was a bit more airflow and the xbox mod helped a bit too. This is also means that the caps will hopefully last longer.
So simply I'd like to know, is there anything I could do to ensure it keeps cool once the HD 7750 is in and the xbox fan is removed or should it be ok?
