Hey guys, I've got a weird problem
Im using a program called 1D Optimizer on a surface pro 3 with the docking system hooked up. Im using both mini displayport connections to two 23" monitors.
The problem is:
When I copy some data from excel, paste it into 1D optimizer, and the program completely freezes, I have to force close it. Its not just excel, its any program(I tried a few to rule out excel).
Now the weird part is: when I disconnect one of the monitors, it works just fine. I tried using a different docking station, different cables, I tried one cable plugged into the docking station and one directly to the surface, it doesn't work when both monitors are plugged in.. Im just so confused as to why this might happen.
If anyone has encountered anything similar to this with any programs or anything please let me know!
Thank you!
The problem is:
Thank you!
