Hi there,
I have a custom built pc. Specs as follows
Asus z170-k motherboard
Intel 3.3 ghz 6600k CPU
Gtx 970 strix 4gb
CM 650 gold+ PSU
16gb ddr4 ram
Tonight I was installing a cpu water cooler and another 8Gb of ram (16 total) and I checked my pc before I got started, everything was fine. But after I finished my motherboard had lights going, power supply's fan was going, GPU had a light and fans going, my lan cable at the back was plugged in and had light but my monitor displayed "no signal" I switched out cables and all, I had a hdmi and tested a vga, didn't work. Tested on my laptop and the screen was showing so my monitor is not broken.
Given that my GPU and motherboard have power and my monitor works on a laptop, what would you suggest I do, given that if either the motherboard or GPU aren't working that that is the problem.
Thanks
Gtx 970 strix 4gb
CM 650 gold+ PSU
16gb ddr4 ram
Thanks
