UPDATE: Gotta Buy a Network Card To install into the PCIE Slot, To Fix this Issue, BAD UPDATE: Monitors TUrn off when playing a Game for roughly 5 minutes Max, And I believe the Computer Crashes aswell, Cant Confirm that theory Though
Please help...
I have a ROG Stix B550-E Motherboard, Issue I am Dealing with is the Ethernet port Disables itself and even if I click enable it does not re-enable, Having to use a USB Ethernet Connector atm just to have internet, The motherboard Does have Wifi Enabled but it is so poor that I cant even run Chrome on it haha but yes, Issue persists Ive tried many different Fixes, Drivers are up to date but the ethernet Diisables Between 5 minutes to 1 hour after restart just randomly whenever I try to do anything at all I will Provide images Im going to test here in a bit to after another restart to see if when I disable the wifi connector if maybe that will fix the issue, but if anyone has any recommendations it would help me a ton
Please help...
