Ok my laptop is a Toshiba Satellite Pro L500, running Windows 7 Professional SP1.
Yesterday, I uninstalled Realtek Audio driver from device manager, then went to realtek and installed the latest driver. Up until I did this, my audio connections worked great. Heres my speaker setup: I am using a Sony Muteki HTM7 7.1 surround system as my speakers. Its AMP is connected via HDMI cable to my laptop's HDMI port. I also have an HDMI out from the amp running to a Samsung hd tv, so im using the tv as the monitor.
So, before, when it was connected, it would show up in Realtek Audio Manager as "HDMI Output", and I could configure it wonderfully there. But now, after uninstalling Realtek Audio driver and then getting the latest version, it does not appear to be going through Realtek. When I first connected the amp back up after getting the new driver, a little message with a blue icon poped up saying that if I wanted audio from the device connected via HDMI then I want need to use and extra optical(or some other port type) cable to get audio. Stupidly, I didnt snipscreenshot this message, as I didnt expect it to actually make a difference, and I thought it might appear again later. So I go to Realtek Audio Manager in the control panel, and now there is NO hdmi tab there at all. But, sound is still being played through my speaker system. I went to sound playback devices, and it showed my speaker system as "AMD High Definition Output/AMD High Definition Audio Device", and it has the laptop speakers as "Speakers/Realtek High Definition Audio". If I set the laptop Speakers as "Default device" then the sound plays from the laptop speakers, and not from the speaker system respectfully.
I have also noticed that now when I play music (Using foobar2000), it no plays the songs in surround. I suspect that this is because that before it went through Realtek Audio Manager, I had it configured to mix stereo sound to surround, and now that its no longer going through the realtek manager, it just plays in stereo, which is really annoying!!
Obviously I thought of rolling back the Realtek driver, so I could use the previous version I had. But in device manager, in the properties of Realtek audio, the "Rollback" option is grayed out. I suspect this is because I uninstalled the previous driver, before I got the new one.
Here are screen snips of my Realtek Audio Manager, and my playback device options:
I will not rest until this abomination has been fixed, I refuse to listen to inferior Stereo music.
UPDATE: The notification appeared again! My AMP turns itself off if no sound goes through it for 5 mins, so it did, then I turned it back on and the notification appeared! Here it is:
Quite an arrogant little message f*cker. It appears, due to its taskbar symbol, to be from AMD/ATI. Which is strange, because my graphics card shouldnt be trying to manage my audio...
