I'm looking to upgrade my RAM and Vid Card so I can run Games like Wither 3 and Fallout 4.
My current setup is getting to slow to run some of the newer games.
I need some recommendations for a Vid card will these questions and maybe some recommendations and triple channel RAM.
1. Can I use a PCI 3 card in the PCI 2 slot and still expect it to be stable. Need Vid card Recommendations.
2.I want to replace the RAM and go from my current 6G to 12G or more. Most of the RAM shown on the ASUS QVL is obsolete and there is no mention of using 8G sticks. Need some help and recommendations. This mobo proved difficult to get the triple channel RAM to work when I built this system.
3. I've overclocked by adjusting the BCLK to 155, PCIE to 100, CPU Ratio to 22 and disabled the Intel Speed Step. This brought the i7 930 from 2.8 base to 3.4. It seems stable and Prime 95 tested it for one hour with max Temp stabilizing at 69c. What difference does disabling the Intel Speed Step do? and should I have disabled it? Is 69c Ok or should I back off the speed a bit.
Current System configuration:
Windows 7 64 Pro
Mobo P6X58D PREMIUM
CPU i7 930
RAM 6 Gig Kingston
Prolimatech Megahalems Rev.B CPU Cooler with 2 120mm fans setup as push pull thru cooler tower.
CORSAIR CMPSU-850HX
WD Caviar Black Hard Drive - 1TB ( 2 of them)
XFX Radeon HD 5870 1GB
COOLER MASTER HAF 932 Case
CD DRIVES ( 2 of them)
Any help would be greatly appreciated.
Thanks
Windows 7 64 Pro
Mobo P6X58D PREMIUM
CPU i7 930
RAM 6 Gig Kingston
CORSAIR CMPSU-850HX
Thanks
