Amd 5950x
X570 gaming arous gaming mb
Some good heat sink with silent wings 3 fans
5x ssd and 2 x m.2 gen 4
Corsair 128gb 32 or 3400mhz ram
Rtx 2080 ti oc
3d max , after effects,c4d. All others I have installed.
What is the best gpu money can buy il buy it.
I need powerfull gpu to render or speed up my workflow.
Ignore gaming.
Ignore gaming I say.
All the gpu reviews on youtube is usless they use games to review stupid.
If I see a gpu that can shred through render and cut down on waiting time this can easily rip through any games you throw at it.
All gaming bench is complete waste of time.
Please provide info what is best gpu I can buy and for rendering purpos only as I explained gaming is nothing. You don't test gpu with games. You do test with rendering with 3d software and stress test.
I need good best gpu money can buy.
And explain to me will I see speed difference and it is worth the upgrade now.
Rtx 2080 ti oc
Ignore gaming.
