Question Upgrade help
lofthouse1982
259
Hi all, I’m thinking of upgrading my motherboard so that I can connect my front type c. I don’t have a spare socket on the actual motherboard. I did buy the small part which plugs into somewhere else on the board but it’s taken up by something else
I currently have
3200 DDR4 32gb across 4 lanes
ASRock B450 Steel Legend (AM4) https://amzn.eu/d/ialqL41
With this case
https://amzn.eu/d/bVTWXNJ
and
Ryzen 7 2700x and GeForce 1660 super
what would be a good motherboard to choose next?
It needs to have
Onboard type c for front socket and rear
7 Sata ssd sockets
2 nvme
thanks Richard
Sorry for not coming back to this sooner. Been sick the past few days.
The problem with getting a board, with what you want, that will work with that CPU really would cost more than it's really worth spending on a 2700x.
PCPartPicker Part List
CPU: AMD Ryzen 7 2700X 3.7 GHz 8-Core Processor (£0.00)
Motherboard: ASRock X570 PG Velocita ATX AM4 Motherboard (£261.44 @ Newegg UK)
Total: £261.44
Generated by PCPartPicker 2023-03-28 00:06 BST+0100
For a similar price, you could do a B550 board, and an R5 5600, which is quite a bit faster than your 2700x, in all respects.
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor (£129.99 @ Amazon UK)
Motherboard: MSI PRO B550M-VC WIFI Micro ATX AM4 Motherboard (£138.00 @ Amazon UK)
Total: £267.99
Generated by PCPartPicker 2023-03-28 00:17 BST+0100
For about £50more, you could get same B550 board, and a 5700x.
Cheap option:
Your system already has dual M.2. It would be cheaper to get an expansion card for your USB C, on the case. https://www.amazon.co.uk/BEYIMEI-Expansion-Connector-Controller-ASM1042A-USB3-2-Type/dp/B0B156WMGC
If I order the 5800x and overclock to 4.6, will I still be able to have my memory overclocked? I don’t touch my graphics card as it seems to misbehave when overclocking it.
so mainly sim racing , odd bash on battlefield and cod. Msfs now and again, but usually photoshop.
This will be better for me 👍 also can the actual 1660 super be overclocked with everything else working harder?
So I got new processor, now for a card. I found this one. Is it any good?
https://www.overclockers.co.uk/gain...ddr6-pci-express-graphics-card-gx-20p-gw.html
https://www.overclockers.co.uk/powe...ddr6-pci-express-graphics-card-gx-1au-pc.html
6650xt is a bit faster, and cheaper.
