Hey Guys,
I need some help choosing an upgrade path. I play a lot of high-end games and i want to be able to play Battlefield 3, MW3 and the new Elder Scrolls game, thats just to mention a few on max settings. I'm currently only running them at 1400 x 1050, in the next couple of weeks i will be upgrading my monitor and i will be running them at 1920 x 1080 full HD.
My current set-up is:
AMD Phenom II X4 840 Quad-Core CPU
Asus M4N68T-M
4GB DDR3 1600MHZ Memory
Geforce 550 TI OC
Currently i have been able to play any game i have thrown at it maxed no problem. But with battlefield 3, MW3 and elder scrolls i dont know how well i will be able to play them on max setting considering it will be full HD. I want to play them on max setting 😛
I will be upgrading but im not sure which way to go. Should i upgrade My motherboard and put another 550 Ti in SLI? Will that give me the boost im looking for?
If i dont go with SLI i was thinking this setup:
Intel Core I5 2500
Gigabyte Z68A-D3H-B3
4GB DDR3 1600MHZ
550 TI OC
Will that setup give me the boost im looking for? I would add a second card a few months down the road.
Just to be clear, I want to know which of the 2 options i have provided will benifit me the most.
Thanks for all you help
Asus M4N68T-M
Geforce 550 TI OC
Intel Core I5 2500
4GB DDR3 1600MHZ
550 TI OC
