Upgrade memory from 1 GB to 4 GB in Compaq Presario v6000 (Model RVO53UA#ABA)
fotafm
I read in a July 2013 post on this site that the Compaq Presario v6000 could work with 4 GB RAM. Compaq website states that 2 GB is max for this model. My model number is RVO53UA#ABA. Will this system accept 4 GB RAM? If so, can you recommend some memory to improve performance?
fotafm
Hi,
Some of the models of the series Presario v6000 support upto 4 GB, but yours will not. Based on the product number, your system model is a Compaq Presario V6305NR. It supports upto 2 GB. For compatible upgrades, refer this link:
http://www.memorystock.com/memory/CompaqPresarioV6305NR.html
Good luck!
Hi,
Good luck!
Thanks for your response. 2 GB it is.
fotafm
Hi!
I've found my old Presario V6000 (V6111EA) laptop in the cabinet a month ago. It has a T2050 Core duo processor, and 1GB ram, intel gma945 chipset.
Since old used laptop parts are very cheap nowdays, I've planned to boost its performance.
The modifications:
New processor: Core 2 Duo T7200 ~10$
Memory upgrade: 4 gigabyte (2x2GB) ~20$
SSD: Samsung 850EVO 120GB (my desktop computer's old SSD so technically it costs "nothing")
Core2Duo supports 64bit operation systems, so all 4GB ram are usable.
All the upgrades worth it's price. It is still not a gamer PC, but it runs every programs much faster (even with the old HDD before the ssd ugrade).
I use chell v1.8 video driver.
I tried WoW The burning crusade with every settings low/off. It is playable if you don't have high expectations. (~40 fps average outside, but under 25 in Stormwind, and high population areas.
