Question Upgrade Motherboard practical advice - issues and gotchas please
Oct 7, 2020
I have on oldish HP desktop. Rather than buy a full replacement, I want to consider swapping out the MB.
I can see an affordable MB/CPU/Memory 'package' on ebuyer.
https://www.ebuyer.com/990377-alphasync-custom-pc-bundle-as-b008
Its also mATX, so should fit.
Q.
Should I expect all the existing connectors to be plug and play?.
Thats only PSU, CD ROM, and 2x HHDs.
Will move to a SSD after the swap.
Existing graphics are and will be onboard.
Q.
Will the BIOS come with the package, I will I have to find/load?
Q.
I currently have an i5-3470. Will it matter moving the setup to AMD?
Q.
Currenlty Win10 Pro.
Will Windows allow me a CPU/Mobo change??
Q.
Anything else to consider??
Thanks for any advice.
Crowii
82
15
10,565
8
A.
The 2600 doesn't have an iGPU.
A.
I doubt it would come without BIOS.
A.
Windows and drivers tend to partially (or completely) break themselves making a move to a whole new platform. It's generally recommended to do a clean install.
A.
Probably not. Chances are it's an OEM license.
A.
Something with onboard graphics, since that's clearly what you want lol.
Latest posts
