My specs are in my signature. Was thinking about starting to buy pieces to upgrade to 4k. I won't be getting it all at the same time, so the order I had in mind was MOBO, CPU, GPU, then monitor.
MOBO - Z790 Asus prob.
CPU - 13th or 14th gen i7 ish
GPU - 4070? Open to suggestions.
I will be upgrading to 2x16 DDR5 7200 CL 34 shortly after.
Just curious what your thoughts are on the order of parts and if you have any changes you would make if you think money is better spent on something else. Thanks in advance.
