Question Upgrade to 4k pc - need help
Sott13
7
I currently have the following components in my PC, except for an SSD which I've recently added. I've been a casual gamer for some time, and it's been several years since I last upgraded my PC. Now, I'm interested in making a significant upgrade to enable 4K gaming. I'd appreciate advice on what components I should upgrade, especially since I primarily play RPG and strategy games.
Below is what I currently have and any help would be appreciated!
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor
Motherboard: MSI B250M PRO-VDH Micro ATX LGA1151 Motherboard
Memory: Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: MSI GeForce GTX 1060 6GB 6GB GT OCV1 Video Card
Case: Rosewill Galaxy-03 ATX Mid Tower Case
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply
6GB won't cut it at 1080p in modern games let alone 4k. What is your budget? You will need at least 16GB of VRAM for 4k (ideally 20-24GB.) Your CPU will probably need an upgrade as well. I would recommend a Ryzen 7 7800x3d and an RX 7900xtx.
Reactions: Sott13
My suggestion is to first upgrade your monitor to 4k.
Then, you can get a better idea of now much graphics and cpu power you need.
You will end up being limited by cpu or gpu and likely both.
If you want a stronger cpu, an upgrade in motherboard needs to accompany a cpu upgrade.
A lga1700 based motherboard using DDR4 ram would allow you to keep your current ram.
A cpu as simple as a I5-13100 would give you twice the threads and twice the compute power.
Run the cpu-Z bench on your 7500. Look at the single thread rating.
Single thread performance is what your type of games need most.
You should get a score about 483:
13100 will be about 678.
If you want stronger graphics, make it a bit jump or you may be disappointed if you do not see magical results.
Tom's gpu hierarchy chart is useful to assess relative capabilities:
I think 4060 class card.
That will likely require a psu update.
750w may do it, but 850w usually do not cost much more.
For example, a Seasonic FX-750 with a 10 year warranty is $105 and the 850w version is $20 more:
Reactions: Sott13
3,000 max is what I'd be looking to spend.
1440P is an excellent resolution for gaming ^^
PCPartPicker Part List
CPU: *Intel Core i7-13700F 2.1 GHz 16-Core Processor ($359.99 @ Amazon)
CPU Cooler: *Deepcool AG620 67.88 CFM CPU Cooler ($43.99 @ Newegg)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard ($159.99 @ Amazon)
Storage: *Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($116.99 @ Adorama)
Video Card: *Zotac GAMING Trinity OC GeForce RTX 4070 Ti 12 GB Video Card ($769.99 @ Amazon)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case ($89.99 @ Newegg)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($118.68 @ Newegg)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit ($121.98 @ Other World Computing)
Monitor: *MSI G272QPF 27.0" 2560 x 1440 170 Hz Monitor ($239.99 @ Amazon)
Total: $2021.59
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2023-10-23 16:37 EDT-0400
A better look at those components.
https://www.msi.com/Motherboard/B760-GAMING-PLUS-WIFI
https://www.intel.com/content/www/u...-30m-cache-up-to-5-20-ghz/specifications.html
https://www.deepcool.com/products/C...al-Tower-CPU-Cooler-1700-AM5/2022/15900.shtml
https://www.crucial.com/products/ssd/crucial-p5-plus-ssd
https://www.zotac.com/us/product/graphics_card/zotac-gaming-geforce-rtx-4070-ti-trinity-oc
https://www.msi.com/Power-Supply/MAG-A850GL-PCIE5
Reactions: Sott13
