[SOLVED] Upgrading Hardware Build Help
Feb 1, 2022
20
Hello,
I have a Lenovo ThinkStation P310. I would like to now upgrade it. I would like to keep the Graphic card (Nvidia M4000, RAM (DDR4 16GB) and also possibly the CPU (Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz, 3408 Mhz, 4 Core(s), 8 Logical Processor(s)). I would like to upgrade the Motherboard, Case and i will prob need a cpu cooler. Which way would you think is best to go around it and also what would you suggest me? I'd say my budget for this upgrade is £300-£400. I have a dual pc set up so i use the ThinkStation for streaming and my second pc for gaming. Thank you.
