[SOLVED] Upgrading my build with the most important parts, first
kwikvinny
232
8
4,595
Upgrading my build with the most important being a new hard tube liquid cooling system with a distro plate on a Lian Li o11 XL ROG appreciate input
Im tranfering all my current hard ware to the new case. My old case was a Lian LI O11WX. Please let me know if you can think of anything im missing and could add for appearance?
I will be upgrading the motherboard, cpu and gpu in the future but anything else you can think of id appreciate the input to make a really nice hobby build. so im trying to go all out but just working on liquid cooling and the looks for right now and smaller hardware items.
Existing....
  • Lian Li o11wx
  • Asus Tuf Mark 2 X299 motherboard
  • Intel i9 7900x cpu
  • Asus geforce gtx 1080 8gb rog strix oc edition gpu
  • (2) Corsair vengeance 16gb DDR4 3200mhz sticks of ram
  • (2) G-skill trident 8gb 3200mhz sticks of ram
  • 1 tb Samsung 970 evo plus m.2 ssd
  • 1tb Western Digital hd
  • Corsair RM850 power supply
New items
-Lian Li o11 XL ROG case
(https://www.newegg.com/black-lian-l...wer-case/p/2AM-000Z-00048?Item=2AM-000Z-00048)
- Singularity o11 XL distro plate that is mounted be replacing the front pane of glass
(https://www.singularitycomputers.co...11-xl-single-d5-reservoir-distribution-plate/)
  • All new clear hard tubing
  • Barrowch FBLTFHI-04N-V2, For Intel Lga115X/X99/X299 CPU Water Blocks, Digital Display Temperature Microwaterway
(https://www.formulamod.com/Barrowch...splay-Temperature-Microwaterway-p1798954.html)
- Barrowch External Expansion Display Screen With 8.8 Inches 1920*480px Multifunction Synchronous Monitoring Interface FBEHD-01
(https://www.formulamod.com/Barrowch...s-Monitoring-Interface-FBEHD-01-p3120342.html)
- Bykski D5 PWM Water Cooling Pumps, Maximum Flow 1100L/H, Maximum Lift 3.8 Meter, CP-NWD5-X-V2
(https://www.formulamod.com/Bykski-D...imum-Lift-38-Meter-CP-NWD5-X-V2-p2840914.html)
- Barrow DK301-16, 16-way Controllers, Full Function LRC2.0 5V RGB Controller, Can Synchronization 5V RGB Motherboard,
(https://www.formulamod.com/Barrow-D...chronization-5V-RGB-Motherboard-p1831967.html)
- LIAN LI ST120-3B ,12CM ARGB FANS , BLACK COLOR , 3 FANS PACK WITH FAN CONTROLLER
(https://www.newegg.com/lian-li-st120-3b-case-fan/p/1YF-005G-00020?Item=9SIAFSTCJZ4520)
-EKWB EK-CoolStream Classic SE 360 Slim Radiator, Triple Fan, Black
(https://www.newegg.com/p/37B-000B-002S9?Item=9SIAGH3CU72827)
- EKWB EK-CoolStream PE 360 Radiator, Triple, Black
(https://www.newegg.com/ek-water-blocks-pe-360-radiator/p/37B-000B-000H0?Item=9SIAEKSAUY3750)
You might want to look into Aquacomputer blocks if you want a temp display on the block itself. I personally would stay away from Barrow and Bykski which are knock off Bitspower brands, that also have their own QC issues, namely being some blocks being incompatible and the build quality overall. If you were a YT'r and they needed marketing space, then yeah you'd be given cherry picked stuff.
Fittings? Angled fittings?
Before you upgrade the cooling, you should address the two mismatched pairs of rams. Work with one brand and of the same model, not two brands of different build qualities.
