the main piece i'm looking at upgrading my mobo, cpu, and memory and i have a slight budget to do so to get the best gaming performance i can out of it, mainly play games like wow (into raiding at a high progression level), sc2, d3, and dota2 for now (if that info helps at all). not looking to oc seeing as i'm going to have to find help to update the bios and everything which means i have no idea what i am doing for the most part when it comes to ocing.
going to list and link my current parts.
case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811103010
psu : XION Supernova XON-800R14N 800W ATX12V / EPS12V SLI Certified CrossFire Ready Modular Power Supply
couldn't find the link for it.
graphics card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127512
hard drive 1: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
hard drive 2: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
cd/dvd burner: http://www.newegg.com/Product/Product.aspx?Item=N82E16827136149
cd/dvd drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827106276
mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131368
cpu: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103649
memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820104098
2 kits
os: http://www.newegg.com/Product/Product.aspx?Item=N82E16832116493
heatsink: http://www.newegg.com/Product/Product.aspx?Item=N82E16835185160
cpu fan: http://www.newegg.com/Product/Product.aspx?Item=N82E16835181015
this is my current build with a 22" widescreen 1680x1050 monitor
looking at upgrading to the parts listed below.
cpu: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116505
mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130646
memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231544
i want to stick with ddr3 1600 1.5v memory.
i want to go with kingston memory since i've had nothing but good customer support from them but having to rma my current memory with them makes me think about looking else where.
feel free to ask me any questions if something doesn't seem right or i missed something.
2 kits
