Upgrading my PC and need some advice
trose07
29
I currently have this
AMD Athlon(tm) II x4 640 Processor 3.00GHz
8 GB of RAM
Radeon HD7770 overclock edition (if that means anything idk)
I want to upgrade so I can play next gen games like Far Cry 4 and other new games on my PC. I can play Shadows of Mordor on medium without a problem and want to ensure this type of performance on higher graphics and more demanding games.
I've been thinking a Radeon R9 270x but don't know what kind of processor to get.
My budget would be about 300$ for both the graphics card and the processor. I've seen the card for about 190$. I've been told a Phenom quad core would be could but I don't know.
What kind of processor should I get in your opinion?
You can see if there are any buyers for your CPU/motherboard/memory on Ebay to make up the difference after you pick the parts you want. Wait for a deal to come along on slickdeal. Or see if you can get a part time job if you have the time.
This is the lowest priced combination I can put together on partpicker. Total comes out to about 360 USD.
http://pcpartpicker.com/p/mP3rmG
@ DonkeyRyder he won't be able to get the fx6300 without also upgrading the motherboard and possibly memory since it's a different socket than the 640.
@ trose07 I'd recommend you save until you can afford a full system upgrade. If you need to upgrade something right now, purchase the graphics card. As I mentioned above, a CPU upgrade usually don't come cheap as they usually come as a package with the motherboard and motherboard compatible ram.
is there anything I can do about my processor without a full system upgrade, I'm 15 without a job so that would be a long time waiting to upgrade.
That's actually not as bad as I expected for everything. How well would that run next gen games like Far Cry 4 (I know i keep bringing it up but it's the only high end game I can think of) though? As long as can run it on at LEAST medium I'm a happy camper. And my current RAM is 8gb and DDR3 or are the ones you picked specifically meant for that motherboard?
that's great, my monitor (which is a small tv) only goes up to 720p so that wont be a problem. Thanks for your help guys, I really appreciate. if you have any more advice please let me know.
Those are the minimum requirements and this build meets it no problem. I was speaking to the recommended requirements.
My bad, I didn't see that. Sorry
