I'm looking to upgrade my current graphics card which is an NVIDIA GeForce GT 640 with 4GB of DDR3 Memory for less then $200. My current PSU is supplying 700 watts.
I would like to play current games as well as play future games that are coming soon.
Here are my system specs:
Operating System
Windows 8.1 64-bit
CPU
Intel Core i7 4770 @ 3.40GHz 85 °F
Haswell 22nm Technology
RAM
16.0GB Dual-Channel DDR3 @ 798MHz (11-11-11-28)
Motherboard
ASUSTeK COMPUTER INC. M51AC (SOCKET 1150) 83 °F
Graphics
HX2000 (1600x900@59Hz)
HT-RC230 (1600x900@59Hz)
4095MB NVIDIA GeForce GT 640 (ASUStek Computer Inc) 97 °F
Storage
1863GB TOSHIBA DT01ACA200 (SATA) 103 °F
931GB Seagate ST31000528AS (SATA) 103 °F
Optical Drives
HL-DT-ST BDDVDRW CH30N
Audio
Realtek High Definition Audio
Current Graphic Card Specs:
Manufacturer NVIDIA
Model GeForce GT 640
GPU GK107
Device ID 10DE-0FC0
Revision A2
Subvendor ASUStek Computer Inc (1043)
Series GeForce GTX 600
Current Performance Level Level 1
Current GPU Clock 324 MHz
Current Memory Clock 324 MHz
Voltage 0.900 V
Die Size 118 mm²
Transistors 1 M
Release Date Jun 2012
DirectX Support 11.1
Bus Interface PCI Express x16
Temperature 97 °F
Driver version 9.18.13.4725
BIOS Version 80.07.ab.00.0e
ROPs 16
Shaders 384 unified
Memory Type DDR3
Memory 4095 MB
Bus Width 64x2 (128 bit)
Filtering Modes 16x Anisotropic
Noise Level Quiet
Max Power Draw 65 W
Count of performance levels : 2
Level 1 - "2D Desktop"
GPU Clock 324 MHz
Level 2 - "3D Applications"
GPU Clock 797 MHz
Memory Clock 891 MHz
Any help would be appreciated.
Thank you!!!
Operating System
Windows 8.1 64-bit
CPU
RAM
Motherboard
Graphics
Storage
Optical Drives
Audio
Manufacturer NVIDIA
GPU GK107
Device ID 10DE-0FC0
Revision A2
Voltage 0.900 V
Die Size 118 mm²
Transistors 1 M
Temperature 97 °F
ROPs 16
Shaders 384 unified
Memory Type DDR3
Memory 4095 MB
Noise Level Quiet
Max Power Draw 65 W
GPU Clock 324 MHz
GPU Clock 797 MHz
Thank you!!!
