Upgrading PC help
apllejack
So I want to upgrade from a gtx 750 to a msi 970, I just need some help with what parts I will need. I need a new power supply so if anyone could recommend a power supply that works with a msi 970 that would be great. Also im not sure if my motherboard will work with the 970, this is a link to the current one I have http://www.gigabyte.com/products/product-page.aspx?pid=4146#ov if it doesn't work could someone show me one that does. Thank a lot!
http://pcpartpicker.com/parts/compare/evga-power-supply-220g20550y1%2Cevga-power-supply-220gs0550v1%2Cxfx-power-supply-p1550gts3x%2Cxfx-power-supply-xfxts550w/
All great power supplies above and yes you have a 3.0 PCIE slot available for the card.
