[SOLVED] Upgrading prebuilt PC - need help!
Everton_
12
I've recently realised that certain components within my rig are due an update, however I initially bought the pc for PC Specialist as I had no prior knowledge at the time of the intricacies of computer building I was hoping to receive some suggestions on how to upgrade the below.
Specs -
Intel Core i5-7600 @ 3.50Ghz 6MB Cache
16GB Corsair VENGEANCE DDR4 2133MHz
Gigabyte Z170X Gaming 3 ATX, LG1151, USB 3.1, SATA 6GBs
3GB NVIDIA GEFORCE GTX 1060 (I now realise that this was a bad idea)
CORSAIR 350W VS SERIES™
Now I'm pretty certain that the GPU and PCU will both need upgrading but I'm unsure of which GPU to go with.
Thanks in Advance!
I'd start with this...
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor (£156.78 @ Aria PC)
Motherboard: MSI B450M MORTAR MAX Micro ATX AM4 Motherboard (£89.98 @ CCL Computers)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory (£79.98 @ Aria PC)
Power Supply: SeaSonic FOCUS 550 W 80+ Gold Certified Fully Modular ATX Power Supply (£79.99 @ CCL Computers)
Total: £406.73
Generated by PCPartPicker 2020-03-31 17:57 BST+0100
… and then save up for a GPU upgrade, something like the RX 5600 XT or 2060 for a worthwhile upgrade.
With the motherboard change you...
IMO, unless you found a used 7th gen i7 for a really good price I don't feel like the marginal gains from hyperthreading are worth MAP.
Would get a better PSU, upgrade the GPU, and if you aren't already use an M.2 NVME or at least an SSD. Get this round of upgrades with your next round in mind (CPU, mobo, RAM) such that you can utilize them usefully into the future.
.02
Total: £406.73
With the motherboard change you will be required to do a clean install of Windows so backup anything important then start fresh. Be sure to grab the newest GPU & motherboard drivers once Windows is finished installing.
Reactions: punkncat
