I have recently swapped 2x8 3200 sticks for 2x16 4400 sticks Ripjaw V Series. My mobo is a msi z390 with i5 9600k.
When I leave my mobo bios at stock, which is 2666 at 1.20 volts, the pc works just fine. However, when I try to increase to 4400 at 1.50 volts (per manufacturer label) my pc will run fine for a few minutes, but consistently freezes. I have tried other voltage settings between 1.2 and 1.5 and same result. Turn it back to 2666 and no problems whatsoever.
I have tried both manually setting values in the bios as well as using the XMP and it happens either way. I have also checked for any bios updates and it is current per msi website. Is there another bios setting i'm missing? MSI website says the board will run 4400.
thanks for the help![Smile :) :)](/data/assets/smilies/smile.gif)
thanks for the help
