Approximate Purchase Date: now till black Friday
Budget Range: $300-400 After Rebates;
Gaming PC
Current Specs
AMD Athlon 64 X2 6000+ @ 3.30GHz
ASUS M2N32-SLI Premium Motherboard
8Gb (4x2Gb) G.Skill (F2-6400CL5-2GBPQ) DDR2-800 @ 5-5-5-15
ATI Radeon HD 4850 X2
Sound Blaster X-Fi XtremeGamer Fatal1ty Pro
Seagate Barracuda 500Gb x2 (ST3500630AS)
CORSAIR CMPSU-750TX (750W) PSU
Gigabyte 3D Aurora Chassis (GZ-FSCA1-ANS)
Windows 7 Ultimate (64bit)
Parts to Upgrade: CPU, mobo, RAM, heatsink
Preferred Website(s) for Parts: newegg.com, microcenter.com, amazon.com
Overclocking: Maybe
SLI or Crossfire: No
Your Monitor Resolution: 1920x1080
Additional Comments: (Prefer if the heatsink isn't too loud, though not a priority)
Why Are You Upgrading: Having a tough time running some games in higher quality. Can only run The Secret World on low settings. RAGE is a lag fest especially in the later areas, could use more frames in Dark Souls, Fable III and so on.
I oc'd cpu to 3.3Ghz from 3.0 and got about a 10 fps boost (Didn't test with many games only The secret world). CPU is pretty outdated now, so I'm pretty sure it's bottlenecking my GPU.
Components I'm considering:
CPU: Can't decide. would prefer to stick with i3 if its sufficient unless i5 trumps it by a whole lot.
Intel Core i5-3570K $220 @ newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Intel Core i3-3220 $130 @ newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116775
MOBO:
ASRock Z77 Extreme4 $105 @ newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
RAM: Going with these for lower latency (don't need more then 8Gb)
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) $70 @ newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231536
Heat Sink:
COOLER MASTER V8 RR-UV8-XBU1-GP 120mm Rifle $48 @ newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103055
So what I'm asking for is for any thoughts, ideas, criticism, is it a good upgrade, is it worth dishing out for the i5 ....etc. w/e
Appreciate any and all feedback.
Thanks in advance.
-Zerx
Gaming PC
Current Specs
Overclocking: Maybe
MOBO:
Heat Sink:
Thanks in advance.
-Zerx
