Question Upgrading system advice
cmolland1808
41
Hiya,
I’m looking to potentially upgrade my system soon, mainly looking at a CPU (Ryzen 7 5800x) and possibly GPU.
My current system specs are as follows:
Motherboard - B450 Tomahawk
CPU - Ryzen 5 2600
CPU Cooler - Stock cooler
RAM - 4x8GB DDR4 @ 3000 Mhz
GPU - EVGA Gtx 1070
PSU - EVGA Gold 650W
Storage - M.2 Samsung evo 970 & Corsair SSD
Case - Cooler Master TD500
Currently using a 1080p monitor but I will likely upgrade to a 1440p in future
My Questions are;
1) Would a Ryzen 7 5800x be a good upgrade and would I need to upgrade my motherboard/other components or would it be sufficient (Possibly considering overclocking capabilities) ?
2) What Graphics Card would be a good upgrade as I was looking at 2070 or 3070 but I’m open to suggestions.
3) I am also looking at a CPU liquid cooler (AIO), what are good options as I’ve mainly been looking at 360mm AIOs for future proofing. What would be a good option for this?
Any advice regarding my system is greatly appreciated!
Thanks in advance :)
Why_Me
Polypheme
Hiya,
CPU - Ryzen 5 2600
GPU - EVGA Gtx 1070
My Questions are;
5700X
View: https://www.youtube.com/watch?v=Kr5V1lgctYw
Reactions: cmolland1808
cmolland1808
41
Save yourself some money and get the 5600 (or 5600X if close in price), you don't need the 5800X
Check out this Youtube video with an RTX 3090, and see why you don't need such a high end CPU
View: https://www.youtube.com/watch?v=zJUUMJNfu5U
For the Ryzen 5 5600x/5600 I did consider this because it seemed a good cost effective option, however i think I’m going lean towards ryzen 7 series as I’ll be using my system for gaming mainly, but also with the occasional design work for my job. So I think the 5700x would be a better fit for this.
IMO the 5700X is a better option for older chipset motherboards as it should stay cooler using less power. Also, overclocking (especially for AMD) IMO is a thing of the past.
I second the 5700x. I have a 5800x and it’s a hot running cpu even with the 240mm aio I’ve got on it. The 5700x as I understand is lower wattage but close to the same performance and should be easier to cool. If I had it to do over I should have gone that direction.
Okay, thanks for linking those videos, they were quite informative. After hearing all your opinions I definitely think I will go with a 5700x as the 5800x seems unnecessary for me.
As the 5700x doesn’t come with a cooler would you guys be able to suggest an effective and reliable cooler? Preferably AIO as I think they look better but if there is good air cooling options, I may consider these. In addition I’d ideally want one that I’ll be able to reuse in future systems.
Thanks!
Reactions: Why_Me
Why_Me
Polypheme
Thanks!
RGB or no RGB?
Why_Me
Polypheme
cmolland1808
41
Reactions: Why_Me
