You only have a couple things to check.
First check the watt number not the VA number they are related but they advertise VA because the number appears bigger. You want one at least as large as your power supply. You really don't have to go a lot above because it is doubtful you are really using 100% of the capacity of your power supply.
Next check the run times. This is complex because they cheat and rate them at different loads. like 1/2 or 1/3 or rarely full load. What you can do is look up the replacement batteries it uses...you are going to have to replace them in 3 years or so anyway. If you find one uses a 7ah battery and the other a 9ah battery you get a basic idea how much power the UPS has to start with. 9 amp hours means it can deliver 9 amp of power at 12 volts for 1 hour. Of course one you convert it to city power of 120 or 240 volts and high amp draw rates that number goes down massively.
Last if you can afford it try to buy a true sine wave UPS. Modern computer supplies because they are so efficient need very clean power. They in theory can get damaged by power that is not sine wave. Not so sure how big a risk this really is UPS makers like to scare people. It would be more a concern if you were running 24x7 on a UPS but a few minutes a years will not cause much issue.
