URGENT* CPU cooler does not fit with dominator ram! Need help!
eapease
5
Hey guys thanks for trying to help here is my build.
Intel i7 7700k
Evga GeForce gtx 1080ti ftw3
Enthoo evolv atx tempered glass
Corsair h115i water cooler
Corsair dominator 32gb (16x2) 3200hz
850w psu
240gb ssd
2tb sshd
SO HERES MY PROBLEM.
When mounting the radiator the second fan does not fit with the dominator ram. Obviously I do not plan on changing rams as I chose the dominator for a reason. What is my options for CPU cooling to overclock a 7700k?!?!?
Need help urgently so I can return h115i soon!!!!
Your cpu will.probably run 10 degrees cooler while your gpu will probably run 2 degrees warmer.
I would say that is a good tradeoff. Especially if you are planning on OCing your 7700K.
I read that the fans would be stressed due to dust filter and I wasn't sure whether it would fit
What would I do with the two preinstalled fans? I already loved them both up but would I just remove them and move them both to top of case as exhaust?
