Urgent help needed. best case for dual reservoir setup.
fergie
256
I am ordering a new case today for a watercooled system. What are the best options for Rampage 3, 2 x gtx480s, with dual reservoir water cooled system. I had wanted Silverstone TJ09 but have been told it is not suitable. I did have the TJ07 so would like a change if possible. Thanks for any sugestions.
Hello fergie;
Take a good look at the Cooler Master Haf 932. Plenty of room for a bottom reservoir and 5 1/4" drive cage reservoir. Will handle a triple 120 radiator in the top of the case too.
Its going to sound silly but I just don't like the styling. Although it does offer everything I need. Are there any Lian Li or Silverstones that would work?
the corsair 800d or 700d(I prefer the latter because I don't like windows) are good choices.
I also don't like the styling of the haf series 😉 but what is wrong whith your tj07?
