[SOLVED] URGENT HELP, PC wont boot after turning on gaming mode in ryzen master
tomas42
Commendable
Jan 24, 2019
18
So i tried to turn on gaming mode in ryzen Master so i select it apply it PC restarts but it wont boot
CPU: Ryzen 5 2600X
MB: msi x370 gaming plus
GPU: EVGA GTX 1080 FTW 2
When it starts, is it giving you the display of the mobo manufacturer's logo on your monitor? If not, you might need to do a clean installation of Windows to get Ryzen Master off of it so it won't automatically apply the overclock. What cooler are you using?
Nothing, no response on monitor, using stock AMD cooler, I believe its amd wraith spire
So should i do clean install of windows?
Also i have been thinking of clearing cmos battery.
