S Sport98 Honorable Mar 22, 2014 5 0 10,510 Mar 25, 2019 #1 I want to add a 4 port USB 3.0 card but all I can find use the PCIe slot. Mine is covered up by my double wide Nvidia card. Any alternatives?
Solution geofelt Mar 25, 2019 What is your motherboard? There are some pcie extenders that you might be able to use. Something like this: https://www.newegg.com/Product/Prod...-9SIAG6K8B53146-_-2&Description=pcie+extender
geofelt Titan Oct 9, 2006 56,063 4,862 174,240 Mar 25, 2019 Solution #2 What is your motherboard? There are some pcie extenders that you might be able to use. Something like this: https://www.newegg.com/Product/Prod...-9SIAG6K8B53146-_-2&Description=pcie+extender Upvote 0 Downvote Solution
Phillip Corcoran Titan Moderator Sep 7, 2013 26,108 913 120,140 Mar 26, 2019 #3 Or you might want to consider an external, mains-powered or bus-powered USB hub, that solves the unusable slot problem. Upvote 0 Downvote
S Sport98 Honorable Mar 22, 2014 5 0 10,510 Mar 26, 2019 #4 The MOBO is a Gigabyte GA-78LMT-USB3 and the slot is a PCIEx1 (small). Upvote 0 Downvote
jsmithepa Polypheme Jun 14, 2014 13,091 264 60,840 Mar 26, 2019 #5 What ^they say. Either an external hub if u already have at least one USB3 port, or a PCIe extender cable assuming the new card doesn't require more than 1 PCIe lane and u have room for the new card. Upvote 0 Downvote
AllanGH Reputable Mar 10, 2019 2,552 538 4,090 Mar 27, 2019 #6 If the PCI slot is unused, just pop one of these in there. Upvote 0 Downvote
