T tomworthington2004.tw Commendable Jan 21, 2018 31 0 1,530 Jan 21, 2018 #1 The cables that run from my USB 3.0 slots on my new case are 19 pin but where it says 'USB_3.0' on my motherboard, there is no pinout. It is just a slot. There is a long part and a small part. What does this mean? Do I need some kind of adapter?
Solution U U unclebun Jan 21, 2018 If your motherboard is a new model, it should have a USB 3 header. But if it doesn't, you can buy pcie USB cards that have internal USB header(s)
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,768 1,840 159,590 Jan 21, 2018 #2 Should look like this if you have one on your board: Upvote 1 Downvote
U unclebun Honorable Mar 28, 2014 214 0 10,860 Jan 21, 2018 Solution #3 If your motherboard is a new model, it should have a USB 3 header. But if it doesn't, you can buy pcie USB cards that have internal USB header(s) Upvote 1 Downvote Solution
