USB 3.0 external 3.5" drive without power adapter?
gggirlgeek
125
Is it possible to have an External USB 3.0 enclosure (for Sata 3.5" HDD) with no power adapter requirement??? Most of the External enclosures I've seen on Newegg have a power adapter. (I see some 2.5" models without them though.) Is this for backup/extra boost or is it needed?
I'm on my last decision before buying all the parts needed for my new system build. The last part: The desktop case.
The difference: The front port either has eSata or USB 3.0 connection. eSata is faster so if I need a power adapter anyway than who needs the USB 3.0?? Know what I mean? :)
3.5" USB 3.0 Enclosure
Yes they did. I wish they had boosted it just a bit more. You might be able to get away with using USB power alone, but as you stated, it will be tight. If the manufacturer provides a power adapter, then I assume it won't be able to draw enough power from the USB port.
If the OP is willing to trade off a 3.5" drive for a 2.5" drive, then he'll have more options available.
