B box o rocks Distinguished Apr 9, 2012 786 18 18,985 Mar 4, 2022 #1 I'm wondering if one of the vbus pins being missing on a USB3.0 motherboard header would keep it from working? It's the one right above the "no pin".
Solution DRagor Mar 4, 2022 You mean pin 1? It's the power pin so one of the ports will have no power. The other port however should work.
DRagor Polypheme Jan 23, 2017 9,096 813 65,440 Mar 4, 2022 Solution #2 You mean pin 1? It's the power pin so one of the ports will have no power. The other port however should work. Upvote 0 Downvote Solution
B box o rocks Distinguished Apr 9, 2012 786 18 18,985 Mar 5, 2022 #3 DRagor said: You mean pin 1? It's the power pin so one of the ports will have no power. The other port however should work. Click to expand... Thanks. Needed to know that. Upvote 0 Downvote
