USB 3.0 help
That cable in the picture is a USB 3 front panel connector with a USB 2 front panel connector coming off it, if your motherboard has a USB 3 header on it then plug the main block into that then the samller block into one of the nearby USB 2 headers.
Dont worry about the TPM connector, dont plug anything into that on the motherboard, thats for a special device that you can buy called a Trusted Platform Module, and would plug into there if you had one. The TPM would be mostly utilized by applications that require or are related to security, such as encryption/decryption, and authentication, windows bit locker etc.
Which motherboard is it ?
It's a gigabyte h110m-a. I only see one F_USB at the bottom of the board that's already taken. Does the USB have to be connected for the 3.0 to work
If the F_USB at the bottom is already taken, just plug main big block into the USB 3.0 header, only the front USB 3 ports on your case will work (the blue ones), the USB 2 ones wont work (the black ones)
What do you have plugged into that F_USB header ?
A 2.0 from the front panel. There's also one coming from the USB 3.0. At the front there is one 2.0 and one 3.0. The 2.0 is already plugged in to the F_USB, so why are there 2 2.0s when there is only 1 at the front
Not quite sure, maybe the USB 2 that is branching out from the USB 3 cable is just in case you dont have a USB 3 header on the motherboard, so that you can use the USB 3 port on the front of the case as a USB 2 port, save it going to waste, but as you do have a USB 3 header on the motherboard, plug into the USB 3 header on the motherboard.
