USB 3.0 speed 5.5MB/s [SOLVED]
Poncke
66
6
18,545
Hi all,
I have a self bullt PC, with USB 3.0 ports. But the speed is very slow at 5.5MB/s.
I have just installed the MSI USB Speed Up app and updated the BIOS to latest version, but no improvement.
I tried the stick in different slots, no improvement.
Kingston 16GB G4 data traveler, and the data is copied from my internal HDD, which is a WD Red 3TB, connected via SATA 6Gb/s
Any ideas to speed this up? Or buy a faster flash drive?
System:
OS Name Microsoft Windows 10 Home
Version 10.0.14393 Build 14393
OS Manufacturer Microsoft Corporation
System Manufacturer MSI
System Model MS-7971
System Type x64-based PC
System SKU Default string
Processor Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, 4008 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 1.H0, 21/12/2016
SMBIOS Version 3.0
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer MSI
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Desktop
Secure Boot State Off
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume6
Hardware Abstraction Layer Version = "10.0.14393.206"
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 16.0 GB
Available Physical Memory 7.13 GB
Total Virtual Memory 18.8 GB
Available Virtual Memory 8.89 GB
Page File Space 2.88 GB
Page File C:\pagefile.sys
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualisation Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
HDD:
WD Red 3TB NAS Desktop Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5 Inch.
Description Disk drive
Manufacturer (Standard disk drives)
Model WDC WD30EFRX-68EUZN0
Bytes/Sector 512
Media Loaded Yes
Media Type Fixed hard disk
Partitions 1
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 1
SCSI Target ID 5
Sectors/Track 63
Size 2.73 TB (3,000,590,369,280 bytes)
Total Cylinders 364,801
Total Sectors 5,860,528,065
Total Tracks 93,024,255
Tracks/Cylinder 255
Partition Disk #2, Partition #0
Partition Size 2.73 TB (3,000,457,232,384 bytes)
Partition Starting Offset 135,266,304 bytes
Description Local Fixed Disk
Compressed No
File System NTFS
Size 2.73 TB (3,000,457,228,288 bytes)
Free Space 1.23 TB (1,353,535,299,584 bytes)
Volume Name MAIN STORAGE
Volume Serial Number E4F42F36
Wow so Sequential Read/Write that is kinda pathetic. Based on what TMTOWTSAC said we could pretty much narrow it down to being a really slow Thumbdrive. Basically a slow drive that has a "USB 3.0" Controller that only benefits read speeds apparently based on the reviews (stated reads near and slightly above 100MB/s).
For a good fast drive I'd try for something like the Sandisk Extreme drives (a good affordable fast USB 3.0 drive) or if you want to stick with kingston their HyperX series of Thumbdrives.
What type of Data are you transferring. The size of the files will affect how fast the files transfer from your HDD to the Flash drive. For instance if I transferred a bunch of small text files from my HDD to my USB 3 flash drive I can expect to get somewhere between 1-10MB/s due to the size of the files. If I transferred large video files I could expect to get 70-120MB/s. I would make sure to run a few tests on different files especially large ones to ensure your HDD is not the issue here.
Have you tried any other USB 3.0 devices to see if they reach full speed? Kingston rates that thumb drive as having "Standard" speed which doesn't mean anything. I took a glance through Amazon's comments and a ton of people complained about the write speed, though they reported anywhere from 8 MB/s to 19.2 MB/s. Kingston reps basically said "We sell faster drives!" after every complaint.
