USB 3.0 uses more physical connections than USB 2.0 does.
Chances are that you have a bad contact, or circuit trace in the Jump drive, in the USB 3.0 exclusive circuitry, forcing the Jump drive to fallback to USB 2.0 operation.
Your best move would be to back-up the data from it while you can, and replace it.
########### EDIT #############
In terms of reliability, I haven't been impressed by Kingston--they used to be the king in the Dram segment a long time back, but just haven't been able to make the transition to reliable NAND technology.
SanDisk, on the other hand, is about as reliable as you can get in the portable flash market.
