[SOLVED] USB Bootable Flash Drive
David_785
Hey, I can't create Bootable flash drive of El Capitan, I downloaded .dmg file but When i try with TransMac Formating to MacDisk and then restoring image to disk ( the El Capitan.dmg file) And put it on Mac it says it's not in Guid partition please help.. thanks in advance
McHenryB
Admirable
Jan 31, 2015
2,021
439
1. Where are you downloading the .dmg file from? I didn't think that Apple supplied their OSs as .dmg files.
2. Why are you trying to create the USB using a Windows PC? Use your Mac.
