Question USB-C dock with Charging
ShaQBlogs
110
I am looking for a Dock for my wife to make her usage of laptop easier. The dock should be able to support data, video and power delivery (Not sure if USB-C supports anything else).
The following ports are required.
  1. USB-C (host PC).
  2. PC to be charged via USB-C (Included power adapter for dock)
  3. HDMI or DP
  4. Ethernet
  5. USB
I came across this, but this is on the pricey side.
Do I have any good reliable options that do not cost 150$?? I would have expected this to be around 50 to 100$.
Any Thunderbolt dock should be OK. The Lenovo docks are a bit expensive but if you buy a used one would be good and I have found matching brands is best for docking stations. For example the Lenovo systems I work on do not boot with certain models of Dell docking stations connected.
Latest posts
