Chaingunchris Honorable Jul 29, 2014 472 1 10,815 Sep 2, 2018 #1 I have an old case and a motherboard with no usb c header on the board. Are there any adapters I can buy that can give me front usb c IO? Preferably under 50$
Solution cin19 Sep 3, 2018 Other option: if your MB has one free pcie slot, you can buy the add-one card,like in the linker, but it is in the back, not in the front. https://www.newegg.com/Product/Product.aspx?Item=N82E16815287033&ignorebbr=1
cin19 Titan Mar 14, 2011 15,726 218 112,340 Sep 3, 2018 Solution #2 Other option: if your MB has one free pcie slot, you can buy the add-one card,like in the linker, but it is in the back, not in the front. https://www.newegg.com/Product/Product.aspx?Item=N82E16815287033&ignorebbr=1 Upvote 0 Downvote Solution
